Message 1 of 30
Re: Boards
Boards? Exactly. Too much jargon, not enough help from BT.
You would think if they said, "Go to boards...", then there would be a link to 'Boards'!
Or is that too much to ask for my £40 a month?
Bored already.
29 REPLIES 29
Message 2 of 30
Re: Boards
HI the term boards is used worldwide for any type of forum indeed at the very beginning of the internet they were called bulletin boards
dnncroz
Newbie
Message 3 of 30
Re: Boards
Hi same question as this originator how does a newby start a new question - I have clicked link forum for How to understand my bill -Is this then the 'board page' if so I do see a new tab.
Tried a number of selections & options cannot see the NEW tab on any of my pages.
Thanks dnncroz
Message 4 of 30
Re: Boards
at the top of each board there is 'new message'  just click there and off you goSmiley Wink
Message 5 of 30
Re: Boards
click on message listing then on the new page you will see NEW MESSAGE on t top left of the page click on that and you can post your own message
woollie
Message 6 of 30
Re: Boards
yes, but where are the found
Message 7 of 30
Re: Boards
http://community.bt.com/
widley12
Message 8 of 30
Re: Boards
Couldn't agree more! Did you get an answer - I need to go to a board to ask a question. Ta!
Message 9 of 30
Re: Boards
Thanks dnncroz
You ask a question by doing what you did to ask this question. Just select the board that you wish to ask the question on. Don't worry if it turns out to be the wrong board it will be moved to the correct one if need be.
glen40
Message 10 of 30
Re: Boards
dooooh where does it say create a question or do you jump onto a thread and ask a totally different question and then wait for some feedback
