Message 1 of 8
Wesbite does not load on internet but does load on 4/5G
Good evening,
A wesbite I use as a hobby will not load via BT internet
Website is eu-football.info
I can access via 4/5G and at other locations but at home on BT internet it will not load.
I have cleared the DNS cache etc.
7 REPLIES 7
Message 2 of 8
Re: Wesbite does not load on internet but does load on 4/5G
Web page loaded without problem for me using chrome
Message 3 of 8
Thanks for checking.
Something on my computer is not happy with it via internet.
Message 4 of 8
Perhaps it is your browser setting. You haven't mentioned which particular browser you are using.
Message 5 of 8
Hi Carlusha - using Chrome but tried Edge and Firefox
Message 6 of 8
Welcome to the Community, @Anorak58.
I've tried this on the BT WiFi in our office and all seems to work as it should with this page.
A colleague who is working from home using EE WiFi experiences no issues either.
Is it BT residential broadband that you're using right now? I can test this myself when I get home later, but all reports I've heard so far sound okay.
Also whilst it would be odd for this site to be flagged as such, have you checked your parental controls to see if these could be having an influence?
Peter
Message 7 of 8
Hi Peter,
I have resolved it by removing a browser checker from my BT log in.
Message 8 of 8
Thanks for the update here, @Anorak58.
I'm glad to hear you managed to get this sorted in the end 😊
You take care,
Peter
