Bowdon
Message 1 of 2
Why are some exchanges listed as District B?
As the subject header. Why are some exchanges listed as District B?
Anyone know what District B stands for?
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Why are some exchanges listed as District B?
@Bowdon Do you mean a market B exchange? If so it's means it is telephone exchange where there are three or more primary operators (ISPs) present. It's used by Ofcom to classify competition between ISP's in different exchange areas.
I hope that helps?
Cheers
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
