Message 1 of 2
ex employee reference via email
I need an employee reference, and the 0800 number does not work from abroad.  Please can you send me an email address where I can request a reference.  Thank you
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: ex employee reference via email
Hi marijkecazemier, I've sent you a Private message explaining how to contact the HR team.
Check here: https://community.bt.com/t5/notes/privatenotespage
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
