Message 1 of 4
modifying posts
How    can you modify posts you  have made
3 REPLIES 3
Message 2 of 4
Re: modifying posts
Click the 3 dots and use the edit function. It is only available for 1 hour after posting
Message 3 of 4
Re: modifying posts
See link for other information about using the forum
https://community.bt.com/t5/help/faqpage
Message 4 of 4
Re: modifying posts
that would explain why i could not modify previous ones
