Message 1 of 7
0345 Numbers
Hi i thought 0345 numbers were free with my calling plan but i was charged 35p for a call i made.
Total cost of usage to date:
£0.35
6 REPLIES 6
Message 2 of 7
Re: 0345 Numbers
Hi, @crocman Thanks for posting, what calling plan do you have?
Neil
Message 3 of 7
Re: 0345 Numbers
Hi i have
700 minutes
Talk for up to 700 minutes every month
Message 4 of 7
Re: 0345 Numbers
@crocman  Thanks for getting back to me. Calling an 03 number should be free using the call plan minutes (20.9p per minute after you've used your minutes)
Are you sure that call was to an 0345 number? The 35p charge sounds more like the facility fee for pressing 3 to return the call after ringing 1471 as it costs 35p to use this function on all calling plans.
Neil
Message 5 of 7
Re: 0345 Numbers
Hi Neil0 here is the call i made.
06 Jan
13:53
0345 6710709
Other calls
00:01:37
Total cost of £0.35.
Message 6 of 7
Re: 0345 Numbers
@crocman we can take a look, I'll send you a private message so you can send over your details.
Neil
Message 7 of 7
Re: 0345 Numbers
Thanks PM sent.
