Valerie1968
Newbie
Message 1 of 5
123 BT unwanted calls charge
Since I have switched from Virgin to BT I have been charged an extract and additional fee of an average of £3 to £5 per month for calls that I do not make. All calls are made to 123 and whilst I have raised this issue several times with BT  the problem still remains. Does anyone have the same problem? Or most important, does anyone have managed to solve this issue please?
4 REPLIES 4
JonathanAnsell
Message 2 of 5
Re: 123 BT unwanted calls charge
Have you had any engineers visit or reported any line problems?
Message 3 of 5
try searching forum for 'call to 123'  there are numerous similar posts to yours which may help  most had money refunded
Moderator
Moderator
Message 4 of 5
Hi @Valerie1968 thanks for posting.  I'm sorry to see you've a complaint regarding the 123 calls on your bill, these calls are to the speaking clock and cost 50p per call.
Do you have any equipment like alarm system that may be automatically dialling this number to check the line is in working order?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Distinguished Guru
Message 5 of 5
Virginmedia charge for speaking clock, so that would have been shown when the OP was with them - unless they had a package which included it ...
There is a potential chance of some form of crossed line since being moved.
