Message 1 of 3
2FA Question
Hey all,
Just a quick question regarding the new 2FA system in place. Is it possible to switch the verification method from SMS to email instead of it going to SMS by default? Would be nice to have the option of sending it to either email or SMS. I'm guessing that it can't be totally switched off .
Tags (5)
2 REPLIES 2
Message 2 of 3
Re: 2FA Question
The 2FA can not be turned off since the upgrade to the system.
I am not aware of being able to change the default method of receiving the PIN however when you log on some browsers such as Edge it gives you the option to get an  email or a SMS.
Message 3 of 3
Re: 2FA Question
Interesting. I just tried with Edge and it sent the code to SMS with no option for email.
