Derek_1947
Message 1 of 3
700 limited minutes plan - consequences of exceeding the limit?
I tend to be just inside 700 minutes per month but sometimes over by a relatively small amount.  If I sign up for the 700 minutes plan and go over 700 minutes in any month, what tariff is used for the excess?
2 REPLIES 2
CJT80
Recognised Expert
Message 2 of 3
Re: 700 limited minutes plan - consequences of exceeding the limit?
@Derek_1947
It's hard to tell based on the current consumer price guide.
One would assume the PAYG rate of 20p per minute.
See page 25 - https://www.bt.com/assets/pdf/BT_PhoneTariff_Residential.pdf
Kind Regards
CJT80
Say thanks by clicking the Thumbs Up icon. Have I resolved your issue? Click "Mark As Accepted Solution"
-Richie-
Guru
Message 3 of 3
If you exceed 700 minutes, you would then pay 20p per minute
If you exceed 700 minutes 2 months in a row, BT would upgrade you to unlimited minutes.
