Message 1 of 5
AMC - Does ordering it mean a new contract?
As per the title really, it says on my Vision + box that I need to upgrade my subscription to receive this channel. I can order the channel online at £0.00 cost but does ordering this channel mean a new 12 mth contract?
4 REPLIES 4
Message 2 of 5
Re: AMC - Does ordering it mean a new contract?
I assume you mean your YouView box, not the old Vision+ box that is being turned off?
Normally you can add and remove channels online, but I don`t think it affects any contract.
I am sure others will confirm that.
Message 3 of 5
Yes it's the Youview box - touch of brainfade there.
Moderator
Moderator
Message 4 of 5
Hi @julesandsand,
If you take a look at What's AMC and how can I watch it?, you can find a few more details about adding AMC to your package.
I hope that helps.
Cheers
PaddyB
Message 5 of 5
Cheers PaddyB that's helpful.
