helzapoppin
Message 1 of 4
Account address
I have got a fault with my fibre broadband and when I reported it the agent asked for my
address and said it was wrong. It’s the same postcode as mine.
bt have sent me a mini hub and that went to the wrong address, I had to
go and collect it.
if I go into my bt / billing account my address is correct.
so I don’t know why my address is wrong with open reach and any
post I get form bt
3 REPLIES 3
helzapoppin
Message 2 of 4
Re: Account address
is it possible to get the mods to check my address what’s on the bt system,
I told the agent over the phone  it was incorrect and they said they would
get it changed, I have also reported this issue before in June 2020 .
I have checked on the Royal Mail address finder and my address is
correct on there.
RobbieMac
Moderator
Moderator
Message 3 of 4
Re: Account address
Hi @helzapoppin
Thanks for your post and welcome back!
Sorry to see that there is a mix up with your address.  As long as you're with us for your landline service, we will be able to get your address detail updated accurately.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
helzapoppin
Message 4 of 4
Re: Account address
Thank you mods, it’s all been sorted out and broadband is now working again.
