finnbarrah
Message 1 of 2
Activation date
I wasn't sure which board to post this to, apologies if this isnt the correct one for my inquiry.
My router arrived on the 6th, and my activation date is the 8th. I plugged my router in on the 6th to see if it powered on and was working ok. It works fine and is connected to the internet, I streamed films and was able to play games without any issue.
Is this supposed to happen? Or should i unplug it until the 8th for any reason.
1 REPLY 1
-Richie-
Guru
Message 2 of 2
Re: Activation date
You're probably using the previous connection, your order might of been a working line takeover, which means the other service is live until you takeover.
Try running a speed test using speedtest.net or fast.com, both will list the ISP.
