United77
Message 1 of 4
Adding Sky Sports 1
Hello All, I would interested to know if anyone has been able to order Sky Sports 1 online? I understood that Sky Sports 1 & 2 could be ordered separately, but when I tried to add Sky Sports 1 to my TV package the only option I get is to add both channels for £22. I only want SS1 for premier league when it starts again in August. Also, for anyone that already has Sky Sports on Youview, how long does it take to activate once you order. Thanks in advance.
3 REPLIES 3
EgreBot
Message 2 of 4
Re: Adding Sky Sports 1
I had it at the end of last season, was live within minutes of ordering.
I've just tried to order and I get the option to add both or add them as individual channels.
magpie03
Expert
Message 3 of 4
I just ordered Sky Sports 2 there, I also only had the option to add both which I did but once you have it in your order you can then edit it and change to one of the Sports channels before conformation.
United77
Message 4 of 4
Thanks for the helpful replies. Much Appreciated.
