DENNISLK
Message 1 of 17
Amazon Alexa
Good afternoon 🙂
I upgraded my broadband to Halo 1 and I'm sure it said I'd receive a Amazon Alexa, but I've had no confirmation of this what's so ever, so would just like to confirm this is still the case.
Dennis
16 REPLIES 16
Keith_Beddoe
Message 2 of 17
Re: Amazon Alexa
@DENNISLK
What date did you place the upgrade order?
DENNISLK
Message 3 of 17
Re: Amazon Alexa
14th January at 00:03
Keith_Beddoe
Message 4 of 17
Re: Amazon Alexa
You will have to wait 14 days after the order closes before anything will happen. What normally happens is after 14 days, and order is sent by BT, to the BT shop who will then dispatch your free gift.
I will however ask a moderator for confirmation on the ordering process, as its seems to vary.
DENNISLK
Message 5 of 17
Re: Amazon Alexa
Thankyou Keith 🙂 you've been really helpful, I'll await confirmation from a Mod
Keith_Beddoe
Message 6 of 17
Re: Amazon Alexa
As this is just a customer forum, its often very difficult to keep track of all of the promotions, but I do know that 14 days applies to broadband promotions, and 30 days for mobile promotions, so you are out of the cooling off period.
DavidM
Moderator
Moderator
Message 7 of 17
Re: Amazon Alexa
Hi @DENNISLK and welcome.
Thanks for posting. @Keith_Beddoe is spot on. There is a 14 period once the order closes so if you don't hear anything by the end of the month post back and we'll take it from there.
Cheers
David
DENNISLK
Message 8 of 17
Re: Amazon Alexa
Thankyou
DENNISLK
Message 9 of 17
Re: Amazon Alexa
Hi David, could you look into this for me now please? Thankyou
Keith_Beddoe
Message 10 of 17
Re: Amazon Alexa
Your order would have only just been sent to the BT Shop, they can take up to 30 days to dispatch your order. Once they have done that, you will receive an email with a tracking link, which you can use to track the order.
