Bogus1
Message 1 of 15
Amazon echo
My broadband went active on 14th dec. when can I expect to get the email allowing me to claim my Amazon Echo.
14 REPLIES 14
Message 2 of 15
Re: Amazon echo
It should be 14 days after your service was activated.
Have you checked to see if the email has gone into the spam folder by mistake?
Bogus1
Message 3 of 15
Re: Amazon echo
Yes, nothing in spam folder, i check it regularly.
Message 4 of 15
Re: Amazon echo
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
Bogus1
Message 5 of 15
Re: Amazon echo
Many thanks.
Moderator
Moderator
Message 6 of 15
Re: Amazon echo
Hi @Bogus1 sorry about the delay replying, the email should have arrived by now if the order was eligible. What date did you place your order on?
Community ModeratorNeilO
Show your appreciation!
Kudos”Kudos”
Bogus1
Message 7 of 15
Re: Amazon echo
30th November
Moderator
Moderator
Message 8 of 15
Re: Amazon echo
@Bogus1 Thanks for confirming that, can you send in your details on the 'click here to contact the mods' link and we'll be happy to help. You'll find the link by clicking on my username.
Neil
Kudos”Kudos”
Moderator
Moderator
Message 9 of 15
Re: Amazon echo
Hi @Bogus1 The Amazon Echo is being processed for you.  The offer you took up does not require you to receive a code and place the order for the Echo. Instead your details are passed to the BT Shop and they process the order for you. You should receive an email from the BT Shop in the next few days to confirm dispatch of the order. I'll keep the case open for a few more days to allow time to receive your Echo.
Cheers
John
Community ModeratorJohnC
Kudos”Kudos”
Bogus1
Message 10 of 15
Re: Amazon echo
Many thanks
Alex
