Nattybatty
Newbie
Message 1 of 3
Amazon echo
Hi, broadband was set up on 7th June and activated but I've still not received any code to claim my free amazon echo. Worried I am about to go out of the 28 days to claim but have received no comms after the initial email??
2 REPLIES 2
-Richie-
Expert
Message 2 of 3
Re: Amazon echo
You'll be sent the code to claim 30 days after your cooling off period, if yours was activated on June 6th, your cooling off period ended on June 19th, you should have it any day now, might be worth waiting a few days incase or check your spam/junk folder of your email, it might already be there.
Moderator
Moderator
Message 3 of 3
Re: Amazon echo
Hi @Nattybatty  did you find an email with the code in your spam/junk folder?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
