Steven1958
Message 1 of 2
Any one help with claiming bt rewards?
Promotion was on when Ordered, all set up and working. Yet trying to claim it says I'm not eligible.
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Any one help with claiming bt rewards?
hI @Steven1958 and thanks for posting.
I'm sorry you're having problems claiming the voucher. Can you confirm the first 3 digits of your online reference i.e. ABC.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”Kudos”
