itpro
Message 1 of 14
BROADBAND USAGE METER
Hello, where can i download this on th bt site? thanks
13 REPLIES 13
Message 2 of 14
Re: BROADBAND USAGE METER
you have posted this twice  you need to delete 1
go to bt.com and sign into my account and then your home phone - should see usage meter link
Distinguished Guru
Message 3 of 14
Hi.
It's not actually a download, it's an online visual display. Go to :-
https://www.bt.com/appsyouraccount/secure/cyahub.do
enter your username/password. Go to the Broadband tab under Manage your services and choose View your broadband usage
robinbredin
Message 4 of 14
I must admit it is very good. The only fault I can see is, that you have to log in too see it, pity it can't be put on your desktop, where it can be viewed more easily.
Malacath
Expert
Message 5 of 14
It's not very accurate.
Mine has said 6.5GB for a week now. I have probably downloaded 30GB over the last week.
hamish72
Recognised Expert
Message 6 of 14
 Malacath
I have compared my with an on PC monitor since day 1 and it is in perfect agreement ?
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Distinguished Guru
Message 7 of 14
Intersting, I too have compared my own figures to the BT ones - and they pretty much macth.
Are you using wireless, and if so can you confirm that you're actually connecting to your own system ? I've certainly had emails over the years via my shortcuts from people who had inadvertently latched onto a neighbour's system!
Also - can you say how you're measuring your use - you do say "probably", so it's not exactly clear if your have d/l 30GB if you don't mind me saying.
smelly
Message 8 of 14
OK i maybe blind here but on MY BT under Manage my services I have a Phone tab and BT Broadband talk tab. The account is the only one i have and I can't see braodband usage anywhere.
Am i missing something??
Rottie
Expert
Message 9 of 14
Hi there,
How long is it since you have had your BB service installed?
The reason I ask, is because when I rang Technical on an unrelated query today and mentioned the fact that my BB usage meter wasn't showing, I was told that it could take up to a week after your service goes live, before the meter is available.
Hope this info helps. 🙂
smelly
Message 10 of 14
Well that could be an issue since it was installed on Friday 8th Oct 🙂
No one ever mentioned that!
Cheers mate. Just sat here downloading the WoW patch and was seeing how much it was downloading
