Community Manager
Community Manager
Message 1 of 1
BT Billing Help Tool
Hi Everyone,
I have come across a really helpful tool on BT.com help that I wanted to share.  This tool will help you understand some of the more common billing questions.  Might save you a call into us or even a Live chat.
When you click on the link below and arrive at the page, select the 'Billing Help Tool' and chose from the options.
Billing Help Tool
Cheers
Sean
Community ManagerSeanD
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
