Message 1 of 9
BT Broadband - Never Again
Hi Peeps,
When I took out my BT broadband contract (7th Aug 2020) I was assured that I could receive Fibre 2 speed at around 73mbps. After a week of 'settling in' I was only getting 48mbps despite paying for Fibre 2 (£29.99).
After contacting BT services I was told this was due to BT having an incorrect postcode, this will be corrected and speed increased within 5 working days. It didn't, BT then sent out an Open Reach engineer out to check my line (this will be the first of four). He confirmed that I was on the 55/10 circuit and that I could indeed get faster speed. To cut a long story short as this has been going on for 4 weeks now, all the engineers confirm that I can go faster and Vodafone which supplied my broadband up until I made a mistake and went with BT, was giving me between 68 to 73mbps, I would guess that BT even supplies the service to Vodafone.
So I was repeatedly told that I would be put on the 80/20 circuit until today when I was told to ring the BT 'Loyalty Team' to confirm that I was on the faster 80/20 circuit. The guy flatly refused to entertain the fact and insisted that I was getting the max speed 55/10 and that was the speed when the contract was taken out - lies. And as I was out of the cooling off period, cancellation chargers would be made if I dared to cancel, despite the fact that I have been in talks with BT within the cooling off period!
So to recap, Vodafone was giving me 68/73mbps, but BT now can't. If I go on the BT website I can get 72/73mbps, 20mbps upload. The FOUR Open Reach engineers say that I CAN get the faster speed. I am paying for the Fibre 2 72/73mbps speed at £29.99 and NOT Fibre 1 46/50mbps at £27.99
I feel ripped off and taken for a ride here, I would like to have taken if further, but the guy refused to raise a complaint. So I am trapped in this contract for 24 months. Is there anything else I can do? I am fed up with ringing the BT 150 number and going all through things over and over.
Steve
8 REPLIES 8
Expert
Message 2 of 9
Re: BT Broadband - Never Again
Give BT another call, ask for the 'Easy Assist' team, they can help
By the sounds of it, it's a change of SLT (service line type) you need, from 55/10 to 80/20 which is a simple process.
Message 3 of 9
VF.jpgBT.jpgHi Richie,
Do you know the number for the 'Easy Assist' team?
I don't want to ring the 0800 800 150 again as I have rung that several times over the last month and got nowhere.
As you can see above... BT and Vodafone both say yes to faster speed.
Steve
Expert
Message 4 of 9
There is no direct number, they are a specialist support team, so you would need to be transferred to them.
Message 5 of 9
You must have received an order confirmation email did you check that shows fibre 2 not fibre 1
Have you checked MYBT to confirm you package is fibre 2
Message 6 of 9
Hi,
Yes my conformation email states Fire 2, but under it is 46-50mbps which is NOT what I wanted. That speed is Fibre 1 at £27.99 pm, I am paying for Fibre 2 at £29.99 pm.
So do I have to ring the 0800 800 150 number and ask for the 'Easy Assist' team?
Thanks for the 'heads up' 👍
Message 7 of 9
Its Openreach that supply the same broadband connection to Vodaphone, BT Retail, and lots of other providers. You would have been connected to a different port, and possibly a different routing, so you may not get the same speed.
Message 8 of 9
I have just spoken to a very nice lady at BT who put in touch with the 'Easy Assist' team who admit there is a discrepancy with my address and will look at it and the very nice lady will ring me next Thursday. So there may be a ray of hope on the horizon.
Message 9 of 9
Just like to give credit where credit is due. Had direct contact with a very helpful chap from BT who has resolved the issue in three days where it took me over 4 weeks and I didn't get anywhere. Now on Fibre 2 where I wanted to be from the start.
Many thanks to all involved at BT and Open Reach and thanks for the input here 👍
