Message 1 of 3
BT Mobile Sim Only Double Data
Hi
I believe I'm entitled to double data on a BT mobile sim-only plan because I've got BT fibre broadband.
But when I enter the BT order online, it only shows the standard data allowance.  I didn't want to proceed in case this was correct and I didn't get double data (which makes the order worthwhile). Will double-data be added after the order is placed despite the order text?
Ron
2 REPLIES 2
Message 2 of 3
Re: BT Mobile Sim Only Double Data
Your double data allowance for mobile comes when you sign up to BT Halo. (You don't need Halo 3+, just Halo).
You can check by calling 0800 800 150, but lines tend to be very busy at the moment.
Message 3 of 3
@Rondo You get £5 off the standard price with BT Broadband.
