kevinbdixon
Message 1 of 5
BT Prepaid Card
Hi,
My order reference is only 18 characters long but needs to be 20 for the claim form.
I'm not confusing the volume reference with the order reference before anyone suggests that.
It starts AJMEAAXXXXXXXXXXXX
Am I doing something wrong?
4 REPLIES 4
Message 2 of 5
Re: BT Prepaid Card
I believe you can use either number to claim the card
kevinbdixon
Message 3 of 5
Re: BT Prepaid Card
Thanks John but the issue is that it wants a minimum of 20 characters but my order number is only 18 so it won't progress. It doesn't work in either box.
Kind regards,
Kevin
Message 4 of 5
Re: BT Prepaid Card
I have asked the Forum Moderators to help you they will post their contact link here
Moderator
Moderator
Message 5 of 5
Re: BT Prepaid Card
Hi kevinbdixon,
I'll be able to help you with your order number. Send me in your details using the "Contact The Mods" link found in my profile.
PaddyB
