Furzul
Message 1 of 3
BT Reward Card
I have received my reward card and activated it, no problem. Is there a length of time before I can use it and can I use it online?
I have tried to use it on Amazon but they say they cannot process the payment method.
2 REPLIES 2
PaddyB
Moderator
Moderator
Message 2 of 3
Re: BT Reward Card
Hi @Furzul,
I'm glad you've received your BT Rewards Card. Once you've activated your rewards card it should be available to use straight away.
You can find out more information here - Information about the BT Reward Card
PaddyB
Samtwin86
Message 3 of 3
Re: BT Reward Card
My friend had one of these rewards card from sky. She was able to use it straight away and use it at most place but couldn’t use it at the petrol stations and she had to use hers within 1 year and it had expire date on it.
