mccallud
Message 1 of 4
BT TV Extra Box
Hello
I am looking to pay the extra £5 for a 2nd BT Youview box (I have already bought the 2nd Box from BT ) But waiting on paying the extra £5 how do I do this I could see anyway on doing it?
D
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: BT TV Extra Box
@mccallud We can help you get that ordered. Please use the 'click here to contact the mods' link in my forum profile to send in your details. You can find the link by clicking on my username.
Neil
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
mccallud
Message 3 of 4
Re: BT TV Extra Box
Hi @NeilO Thanks for this I have provide the info requested another question will the 2nd box work with broadband extenders ? or does it need to be a network cable plugged into the router !
mccallud
Message 4 of 4
Re: BT TV Extra Box
Hi Again @NeilO I have answered my own question yes you can
Thanks Anyway
