thegas
Message 31 of 42
Re: BT Took Over My Telephone Line Two Weeks Early
Connected and working, finally! Smiley Happy
Dean007
Recognised Expert
Message 32 of 42
Hi @thegas
I've just popped a bag of doritos to celebrate! Now don't play with the connection for a few days.. let it do its thing Smiley Happy
thegas
Message 33 of 42
Now trying to figure out why I'm only getting 20MB download when i was getting 35MB with Sky previously.  Smiley Very Happy
Dean007
Recognised Expert
Message 34 of 42
@thegas
Now see I knew you would ask that lol, let DLM do its thing for a few days. Your speeds may go up or down... but for now do not unplug or restart the router!
thegas
Message 35 of 42
Glad you said that, i was considering moving it upstairs to a different socket!
Why should it be left alone for a while out of interest?
Dean007
Recognised Expert
Message 36 of 42
@thegas
DLM will monitor your line, and will increase or decrease your speed depending on how your line performs... They say it can take upto 10 days to settle but often sooner! BT will not do anything about speed until the 10 days is up unless a fault shows.
I would leave it over the weekend, what broadband package did you take? And what was your minimum speed on your confirmation email?
PS for best results ensure you are using the microfilter unless the BT Master Socket is prefiltered and the router is in the master socket and not any extensions.
thegas
Message 37 of 42
Spoiler
We estimate your download speed will be between 31Mbps and 40Mbps, and your upload speed will be between 5.7Mbps and 8.3Mbps.
The minimum guaranteed speed you can expect from your broadband will be 27Mbps.
thegas
Message 38 of 42
Spoiler
Superfast Fibre Essential Unlimited
  • Unlimited usage
  • Average 36Mb download speed
I'm using the filter and it is plugged into the socket in the front room, same location as the sky setup before it.
Dean007
Recognised Expert
Message 39 of 42
@thegas
Providing its in the same socket as when you had it with sky it will go up. Speedtest should be done via a wired connection.
Best place to see whats happening is from your BT Hub,
From a Smart Hub, can you go to hub manager http://bthomehub.home/ then advanced, then technical log. From here you can see your current sync speed, and what the maximum line rate is for your line.
Best adivce for now, sit back enjoy watching France loose at the football and see how it is next week!
thegas
Message 40 of 42
oard version:
1.0
Gui version:
1.64.0
DSL uptime:
0 Days, 0 Hours 42 Minutes 43 Seconds
Data rate:
7.49 Mbps / 23.28 Mbps
Maximum data rate:
7491 / 27662
Noise margin:
6.2 dB / 6.2 dB
Line attenuation:
23.3 dB
