Message 1 of 4
BT Whole Home Wifi
I ordered Bt fibre 2 broadband yesterday and was thinking of adding the whole home WiFi package at £12 per month. Is there a difference between routers and is there any difference if I went and bought the discs separately? Which discs do I buy? I know it’s a lot of questions but I am a bit clueless when it comes to this.
3 REPLIES 3
Message 2 of 4
Re: BT Whole Home Wifi
@Jdb1976
The black disks, but they are about £100 each if you buy them outright.
Message 3 of 4
I can't comment on BT whole home but can say that Fibre 2 with Complete WiFi added at £7 mth has worked superbly in this large 5 bed house.  Unlike whole home you do not need to keep one disk connected to the smart hub by ethernet.
Message 4 of 4
The Whole Home system is a standalone WiFi mesh system that can be used with any ISP or router, it is not restricted to BT.
The Complete WiFi integrates with the Smart Hub2 and can only be used with the SH2.
