Message 1 of 8
BT WiFi upgrade
I am looking to Upgrade or boost I don't really know from my WiFi from Halo 3 to Full fibre 100. On the Halo 3 it says
You'll get a free upgrade to Full Fibre 100 as soon as it's available in your area
I am just wondering if this is a legit offer and what it would do to my monthly payments.
Would they increase? Is it a new contract I sign?
If anyone has done the same thing I would love to hear what happened with it.
7 REPLIES 7
Anonymous
Not applicable
Message 2 of 8
Re: BT WiFi upgrade
I believe that the free upgrade to Full Fibre only applies to Halo 3+, not Halo 3.
If you do have 3+ then you should not pay more and will not have to recontract, no matter what BT tell you.
Full fibre promise...Full fibre promise...
Full fibre is not available here yet so can't comment on the mechanics of the process.
Message 3 of 8
Re: BT WiFi upgrade
Cab I have the link to the page for the TandCs to look over them. Thanks
Anonymous
Not applicable
Message 4 of 8
Re: BT WiFi upgrade
Of course, head here for the detail: BT Halo 3 and 3+ terms
Anonymous
Not applicable
Message 5 of 8
Re: BT WiFi upgrade
@Average-User
Couple of points:
You quoted Halo 3 but @Anonymous has linked to Halo 3+.
While the T&Cs for Halo3+ clearly state that you don't need to recontract, actually getting BT to honour that seems to be another matter.
https://community.bt.com/t5/Bills-Packages/Full-Fibre-Promise-on-Halo-3/m-p/2379603
Anonymous
Not applicable
Message 6 of 8
Re: BT WiFi upgrade
Because the terms and conditions are on the same page, with Halo 3, first followed by 3+.
I give up.
Anonymous
Not applicable
Message 7 of 8
Re: BT WiFi upgrade
@Anonymous
Apologies, posted in haste. I meant the text that you posted rather that the link. But had also missed that you'd already highlighted the difference between Halo 3 & 3+. 🤐
Anonymous
Not applicable
Message 8 of 8
Re: BT WiFi upgrade
Apology accepted 🤣 👍🏻
It doesn't help that the Terms & Conditions are lumped in together and that so many even exist!
I agree on the struggle to get BT to adhere to them, highly recommend saving them as a PDF.
