croftlea
Message 1 of 6
BT activation failure
i applied for bt infinty in july, was given an activation date of 25th august however it failed to activate, i have been given several more activation dates since then and it still isnt working, phoned BT last night and they said there was an issue and it would be fixed within 24 hours however it still isnt fixed. BT home hub 5 has a orange light with a red broadband light.
5 REPLIES 5
Message 2 of 6
Re: BT activation failure
i have asked mods to help
Moderator-Retired
Message 3 of 6
Hi croftlea,
Welcome to the forum and thanks for your post.
I can take a look at your order to see what is causing the delay and hopefully get things speeded up. Can you send me in your details using the "Contact The Mods" link found in my profile and I will be in touch.
Cheers,
OlgaC
Community ModeratorOlga
Show your appreciation!
Kudos”
Make sure you are logged into the forum otherwise you will not see our contact link when a moderator offers help. When sending us your details please don’t send a Private message (PM), we can’t deal with account/service issues via PM so please use the contact link. Thank You
croftlea
Message 4 of 6
have sent my details inc my latest ! order number, many thanks
Message 5 of 6
The forum mods normally reply within 3/5 working days after you have contacted them via their contact form
They will contact you personally by email or phone.
croftlea
Message 6 of 6
fantastic broadband up and running, many thanks
