Message 31 of 36
Re: BT charge £81 a month for broadband services forever?
Issue is the resolution has been promised over and over again and has not happened.
In reply to other post date was 05/09/25.
And I'm not sure what the FTTP or FTTC thing is, but the landline and call package stopped on the correct date.
Still being charged for broadband.
TV was sorted out after a couple of weeks (it's not showing as part of the next bill (only broadband).
Mobile phone was sorted out after a couple of weeks after BT originally sending PAC code that didn't work.
Message 32 of 36
ok if anything fails to happen complain to bt ofcom or what ever you feel is needed
we are only uses of bt services with a bit of knowledge at least I am
 thven tho they have just made a mistake give them time to slove this
Message 33 of 36
They have had the best part of a month to resolve the issues
I understand mistakes can be made......it's just very annoying to resolve it and then to find out it's not resolved and to repeat a number of times
I just don't appreciate being lied to - if they can't resolve it - just say that - don't say they have resolved it and pretend to make notes on the account
That sort of behaviour doesn't help anyone and just gets people's backs up
Message 34 of 36
"just don't appreciate being lied to"
if your saying this and your actively been lied to it could actuuly be the other provider failing to tell them the switch hadint been completed when it had or a system fault
i admit i wouldint be very happy if I was in the postion this isnt helping give them time to sort this out
Message 35 of 36
Did you basically plug the Sky router into exactly the same place as where the BT router was  (so you swapped one for the other ) , and no installation work necessary by Openreach or City Fibre , so whatever Openreach network you were on with BT , was the same with Sky, and your Sky broadband and Sky phone service worked pretty much immediately after you replaced the BT router with the Sky router  ?
If that’s the case , and you used the OTS system to manage the migration, did you get an impact statement from BT ?
Part of the OTS process is as soon as the new company identify your service and indicate a migration is being considered , the losing provider automatically send you a notification showing any termination charges (if still inside a contract) and what equipment needs to be returned etc , that’s the ‘impact’  of what the migration will mean to you  …if you never got that impact statement, ( and as you never received any information about returning the BT router )  , suggests BT were never automatically told you were off to Sky , if that was the case the initial fault was not with BT , if you did get an impact statement then BT were culpable.
Message 36 of 36
kind of understand what your saying
but they were def told about the landline (call package etc) as that stopped on the correct date
so one part stopped and the other part didnt automatically
