KTKaute
Message 1 of 4
BT messed up order 3 times now - can I cancel? #2
Omg this is happening to me 😞
3 REPLIES 3
KTKaute
Message 2 of 4
Re: BT Infinity - order cancelled!
Happening to me. They've assigned a caseworker but doubt this will help this time. If they screw up a fourth time in gonna have to give up on them
Moderator
Moderator
Message 3 of 4
Re: BT messed up order 3 times now - can I cancel? #2
Hi @KTKaute,
I've moved your posts as the threads you posted on were quite old. I hope your case handler is able to resolve this for you but if you're still having problems post back and we'll try to help.
Cheers
David
Community ModeratorDaveM
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
KTKaute
Message 4 of 4
Thank you! 🙂
