antwerp
Newbie
Message 1 of 2
Bills for more than 15 months
Hello,
I wonder how can I see a history of my bills for more than 15 months online?
Thank you!
1 REPLY 1
Moderator
Moderator
Message 2 of 2
Re: Bills for more than 15 months
Hi @antwerp  welcome to the forum and thanks for your post. You can only view bills for the last 15 months online.  If you do need bills from further back then you would need to arrange for a paper copy. This costs £4.80 for every copy.
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”Kudos”
