Newbie
Message 1 of 30
Broadband Activation gone wrong.
Hey, I need your advice - my broadband was supposed to be active yesterday and today I've called and they've said that there was a problem activating the BB and they'll review on the 5th of December. I had to call 3 times just to get that information.
Is there an escalation process I can take because OMD wouldn't take it further and now I'm stuck with no BB for over 2 weeks and no real reason as to why. Sky cut off which means the line is fine and with us, the engineer says it's all ok in the cab so how do I find the answer? I don't want to keep ringing and ringing but this is ridiculous.
29 REPLIES 29
Message 2 of 30
Re: Broadband Activation gone wrong.
Is your BT Retail phone line working? If so, can you do the following.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
See if the cabinet shows available, or waiting list.
Newbie
Message 3 of 30
BT BROADBAND AVAILABILITY CHECKER
Telephone Number *********** on Exchange LONDONDERRY is served by Cabinet 63
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
Left in Jumper
FTTP on Demand 330 30 -- Available -- --
ADSL Products
Availability Date
Left in Jumper
WBC ADSL 2+ Up to 15.5 -- 13.5 to 18 Available -- --
WBC ADSL 2+ Annex M Up to 15.5 Up to 1 13.5 to 18 Available -- --
ADSL Max Up to 8 -- 7 to 8 Available -- --
WBC Fixed Rate 2 -- -- Available -- --
BET Up to 2 -- -- Available -- --
Other Offerings
Availability Date
VDSL Multicast -- -- -- Available -- --
ADSL Multicast -- -- -- Available -- --
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market B Exchange.
There is an open order on your line which is due to complete by 21-Nov-2016.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 20-Nov-2014; the Formal Retirement date for Datastream is from 27-Nov-2014. The Stop Sale date for IPstream is from 30-Nov-2012; the Formal Retirement date for IPstream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
Newbie
Message 4 of 30
Sorry I can't format it properly on the phone. But that's the results on the page. There doesn't seem to be anything standing in the way?
Message 5 of 30
Did you order normal broadband, or fibre broadband?
It may simply be a shortage of field staff to do the work.
Try the  Order Live Chat Team
Newbie
Message 6 of 30
BT had to give me a new number before they could progress my order, they gave me no reason why for that either cause I'm upstairs from the cab and 5 mins from the exchange.
Ok. So. What do you recommend doing?
Newbie
Message 7 of 30
Ordered fibre, I had sky fibre in before also! Thank you.
Message 8 of 30
Is the phone line now working? If so, how long ago?
Newbie
Message 9 of 30
Phone line is working fine, I don't use a landline but the engineer let me hear him call out on it yesterday
Newbie
Message 10 of 30
24 hours
