Message 1 of 5
Broadband Upgrade overlap concern
My current broadband contract was set to expire on the 09/02/2022 ; I've just upgraded it to a new package, for which the earliest activation date was the 14/02/2022.
My partner and I both work from home and require internet access in order to do our jobs; and I'm concerned that we might not have broadband on the days between the 09/02 and the 14/02.
Is this the case? If so, is there anything I can do to correct it?
Many thanks
4 REPLIES 4
Message 2 of 5
Re: Broadband Upgrade overlap concern
What have you upgraded from and to?
Message 3 of 5
Regardless of what you're upgrading to the answer is no. Once your old contracr ends the service continues on a monthly rolling basis it doesn't just stop
Message 4 of 5
I upgraded from Fibre 1 to Fibre 2
Message 5 of 5
It will just be the removal of an artificial speed cap when the package is activated, as @garybs29 has said, nothing will happen until activation which will just be a momentary blip in service.
Are you sure your line is capable of Fibre2?
What speed is shown in the checker if you enter your phone number https://www.broadbandchecker.btwholesale.com/#/ADSL
Can you post a screenshot of your hub stats?
