Debw1
Newbie
Message 1 of 4
Broadband reward card
Hello, I had Ultra Fast Fibre Plus installed on 13th December and am still waiting for my reward card to show on my account so I can claim it. I spoke to Bt before Xmas and they said it would show 18 days after installation, it is way past that now, and still no reward showing. Please advise who best to contact. Thanks
3 REPLIES 3
Moderator
Moderator
Message 2 of 4
Re: Broadband reward card
Hi @Debw1 Sorry you are having a problem claiming your reward card.
Did you place an order via bt.com?
Cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
Debw1
Newbie
Message 3 of 4
Yes it was with Bt. I have since spoken to them again regarding this and they have advised me that they have claimed it on my behalf so I should be receiving it shortly.
Many thanks
Moderator
Moderator
Message 4 of 4
Hi @Debw1 Thanks for posting back and glad to hear someone has submitted the claim for you. If you need to chase the reward card (they can take 30-45 days) check out Claiming a BT Reward Card and there is a link to put your query to the promotions team directly.
Cheers
John
Kudos”
