Message 1 of 6
Bt contract expiry
If I cancel my contract how much will bt charge me if I want to keep my bt box pro?
5 REPLIES 5
Message 2 of 6
Re: Bt contract expiry
If you have had the box prior to 13th December 2019 the box is yours to keep otherwise see link
How to return and recycle your BT equipment for free | BT Help
If you are leaving before your contract has ended you will also be charged early termination fees
See link
Leaving BT | BT Help
Message 3 of 6
The Pro box was released in 2021, which means it remains the property of BT, the charge for not returning it is £140 and it will lose some functionality without an active subscription.
Message 4 of 6
In which case that obviously means he has not had it prior to 2019 so he should refer to the link as I suggested!
Message 5 of 6
Thanks for that. I can get  a grade A at CEX for £78
Message 6 of 6
Expires March 31st, so began March 2022.
I also have the 4k ultra box, which I managed to keep after discussions with bt, so hopefully I may work out some deal, especially since these boxes are now defunct, being replaced with the EE badged replacement
