baobeiiiii
Message 1 of 2
Bt infinity to infinity 2 upgrade - cancellation
Hi,
so today i got a letter from bt in inbox offering bt infinity 2 for 34 quid a month. I called them up and accepted the offer, with an activation date on 3rd of April.
My question is, can i cancel this upgrade tomorow without being charged a fine? I've decided i'm not happy with the length of the new contract (24 months) and just want to keep my existing contract with no changes. I can get max infinity 2 speeds if i upgrade, but 24 months... just so long.
Possible?
Thanks.
1 REPLY 1
Message 2 of 2
Re: Bt infinity to infinity 2 upgrade - cancellation
Shouldn't be a problem.
