Moderator
Moderator
Message 11 of 13
Re: Bt max hd
Hi @merrick,
Thank you for sending in your details. I gave your home number a quick call, I'm sorry I didn't get speaking to you. Looking at you details I can see the BT Sport was activated yesterday. Please can you let me know if the service is now up an running?
PaddyB
Community ModeratorPaddyB
Show your appreciation!
Kudos”Kudos”
merrick
Message 12 of 13
Re: Bt max hd
Thank you Paddy B. My bt sport is now up and running. Now , who do I speak to about compensation for the delay/disruption.
Moderator
Moderator
Message 13 of 13
Re: Bt max hd
Hi @merrick,
Thank you for taking my call, I'm really happy to hear the BT sport is back working as it should.
I'm just sorry this took longer than expected to fix.
Cheers
PaddyB
Kudos”Kudos”
