Message 1 of 7
Can't order broadband despite already having a line.
Hi All,
So I really do not know what is going on but it seems what ever ISP I try. I cannot order broadband.
It's ever since I switched from SKY something has not been right with my line. I cant even check on ADSL checker. Please can I have someone look into why my line is such a mess.
It's like I am still linked to sky somehow even though I am BT and have been since March 2022..
6 REPLIES 6
Message 2 of 7
Re: Can't order broadband despite already having a line.
Have you tried phoning CS 150 or 0800800150 from mobile as they should be able to help you.
Do you have broadband only - no landline to make or receive calls?  Or are you on digital voice?
Have you checked MYBT to see if any outstanding orders
Message 3 of 7
@imjolly I've been lumbered with DV.. 😞
Message 4 of 7
Then that is reason dslchecker is not working nor does btspeedtester.  I reported this well over a year ago and nothing has changed
Message 5 of 7
That makes sense.. Yeah cant use speedchecker neither.. It's ever since I went DV.
So does that mean I have an SOGEA line then and DV is just VOIP? This would make sense to me if confirmed that this is the case.
Off topic. Because I am also confused why my line stats havent changed in 2 months despite leaving the router on.
Message 6 of 7
Your connection stats will only change when your hub drops connection or resets
Message 7 of 7
I know this but I used to happily sync in at 74meg and now its 66meg.. I just want my line sorted and speed back... been going on way too long.. When you live in the sticks, speed matters. ROLL ON FTTP.
