Message 1 of 2
Cancel my two BT accounts
I have had enough of using BT with its poor homehubs.  How do I cancel my two BT accounts?
Regards
Gary
1 REPLY 1
Message 2 of 2
Re: Cancel my two BT accounts
That can only be done by ringing BT on 0330 1234 150
You would be liable for any cancellation charges if you are still in a contract.
If you do not use BT Digital Voice, then you can use any compatible 3rd party equipment, you do not have to use the BT Home Hub.
