eatmypig
Message 1 of 3
Cancelling Sky and told i may have to watch BT sports
Hi, i've just had my Sky renewal and have decieded to cancel it, whilst on the phone with sky i was told i may have to pay to watch BT sports now, on my recent renewal with BT i was told my BT sports was free via the sky platform, does anyone have any experience with this ? thanks Lee
2 REPLIES 2
-Richie-
Expert
Message 2 of 3
Re: Cancelling Sky and told i may have to watch BT sports
They told you the wrong information, they can't alter or see what arrangement you have with BT, your promotion will remain the same.
If you have a Q box Sky will want it back, If you have a HD box it's yours to keep, also if anything goes wrong or the viewing card needs paired up again, you're out of luck with no support, fingers crossed it keeps running ok.
Part of your BT Sports on Sky package also allows you access to the BT Sport app and to watch on the online player at www.btsport.com
The version of the app you have would support casting, so a cheap chromecast is an option to keep it on your TV, If you have BT broadband then you could also see about BT TV.
Moderator
Moderator
Message 3 of 3
Hi @eatmypig @-Richie- is correct that Sky cannot change your arrangement with BT.
Cheers
John
