Message 1 of 5
Cannot sign in to My BT
Once again I cannot sign in to My BT.  It has happened in the past, two or three times!  I have tried clearing my cache in Firefox, etc.  Thunderbird is working fine and I can access BT on my phone, so I do not want to change my password, which I am absolutely sure is correct.
4 REPLIES 4
Message 2 of 5
Re: Cannot sign in to My BT
Hi jeffw, I got exactly the same issue (using correct ID & PW), but when using MS Edge browser. Only thing that works for me is if I use Google to sign-in. Then all works ok. I reported this to BT, but just said everything ok their end. Although not good for you, as least I know it not just me being a donkey.
Message 3 of 5
Me too. Also failing to log in using Safari in my iPad and the iPad MyBt app. Hope it’s a temporary thing!
Message 4 of 5
 AndyBucks25
Its good to know that you are not alone!  Following your suggestion, I have found that I can sign in with Chrome, which proves that my sign in details are correct.  When I have a moment I will try the other three browsers I have.
Many thanks
Message 5 of 5
I'm glad it worked for you as well.  I went down route of clearing history and using "forgotten password" function even though ID & PW correct, but still had no joy.  However, if there so many people experiencing problems signing in to BT.  It got to suggest it a BT problem and not us poor mortals, despite BT stating there nothing wrong their end!!!
It strange problem affecting different browsers, except Google?
Unless anyone had this issue using Google?
