imjolly
Message 11 of 16
Re: Capacity Issues
Strange your phone number or address works in the dslchecker  try post code but that is least accurate
Does your landline work or is it dead with no dial tone
terryhoward18
Message 12 of 16
Re: Capacity Issues
@imjolly My landline is working.
I can’t get a return on any of the checks, phone number,  postcode or address
imjolly
Message 13 of 16
Re: Capacity Issues
That really is odd as people who are not BT customers get the address and post code check to work just not phone number  -  unless you are on DV  phone number does not work but addressdoes
terryhoward18
Message 14 of 16
Re: Capacity Issues
@imjolly What’s DV.
It appears to be all down, I’ve tried multiple addresses/ phone numbers.
looks like the whole websites broken.
terryhoward18
Message 15 of 16
Re: Capacity Issues
Looks like it’s back up and running. And yes, appears to be a waiting list.
Address BARRACKS LANE RAVENSMOOR, NANTWICH CW5 8PR on Exchange NANTWICH is served by Cabinet 32
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream HandbackThreshold(Mbps) WBC FTTC Availability Date WBC SOGEA Availability DateHigh Low High Low      VDSL Range A (Clean)
VDSL Range B (Impacted)
30.92064.117.1Waiting listWaiting list
30.217.263.713.1Waiting listWaiting list
Featured Products Downstream Line Rate(Mbps) Upstream Line Rate (Mbps) Downstream Range (Mbps) Availability Date FTTP Install ProcessFTTP on Demand
33050--Available--
ADSL Products Downstream Line Rate (Mbps) Upstream Line Rate (Mbps) Downstream Range(Mbps) Availability DateWBC ADSL 2+WBC Fixed Rate
Up to 1--1 to 3.5Available
0.5----Available
Other Offerings Availability DateVDSL MulticastADSL Multicast
Available
Available
Exchange Product Restrictions StatusFTTP Priority Exchange
WLR Withdrawal
SOADSL Restriction
N
N
Y
The exchange is not in a current fibre priority programme
WLR is currently available at the exchange
SOADSL is restricted at the exchange
FTTP is not available
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage
Actual speeds experienced by end users and quoted by CPs will be lower due to a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for IPstream is from 31 Dec 2012. The Formal Retirement date for IPstream is from 30 Jun 2014.
In order to be eligible for handback, downstream speed should be less than Downstream Handback Threshold values.
If you decide to place an order for a WBC fibre product, an appointment may be required for an engineer to visit the end user's premises to supply the service
imjolly
Message 16 of 16
Re: Capacity Issues
As you have and others have said the problem is there is a waiting list so no connections are available to you
