murph2019
Message 1 of 5
Cashback rejected
Topcashback have just rejected my cashback. BT changed my original order and gave me a new order number. Can anyone help me with this?
4 REPLIES 4
Moderator
Moderator
Message 2 of 5
Re: Cashback rejected
@murph2019 I'm really sorry to hear there were issues with your order and cashback claim. Have you filed a missing cashback claim with Topcashback yet?
You'll need to provide them with your new order number for them and they can link the cashback to the new reference.
Community ModeratorNeilO
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
murph2019
Message 3 of 5
Yes I've done that earlier today. Hopefully that will work, it doesnt give you anywhere to explain what happened but I was able to input the more recent order number. The only thing is it can take them quite a while to look into this.
Moderator
Moderator
Message 4 of 5
Hi @murph2019
Thanks for replying!
Keep us posted how things go with this.  If you are still having problems post back and we will give you a hand from here.
Cheers,
Robbie
Community ModeratorRobbieMac
Kudos”
murph2019
Message 5 of 5
Oakey doakey will do
