Mlees956
Message 1 of 6
Cashback through Top Cashback
Hi, I joined BT on 1st January through TopCashback. I am due £90 cashback from BT but it’s currently just sat with BT. How long does it take for the money to come through? The order number begins with AJM.
5 REPLIES 5
Message 2 of 6
Re: Cashback through Top Cashback
Welcome to this user forum.
When was your service activated?
Mlees956
Message 3 of 6
Hi Keith, I think (off the top of my head) 10th Jan! It was definitely around that date.
Maz
Message 4 of 6
Maz
Its probably a bit early for me to ask one of the moderators to chase this, as judging by past cases, it can take quite a while for the promotions team to approve any cashback.
The fact that you have the correct order reference letters, and its in hand with BT, is a good sign that things are progressing.
I would suggest that you give it a few more weeks, and if it has not been approved, then please post back on this thread, and one of the moderators can be asked to assist.
If it does get approved, please can you update this thread. Thanks.
This other thread is an example of what can happen https://community.bt.com/t5/Bills-Packages/Pending-Top-Cashback/m-p/1907491#M104337
Mlees956
Message 5 of 6
Thanks Keith! Much appreciated!
Moderator
Moderator
Message 6 of 6
Hi @Mlees956 Welcome to the forum and thanks for posting.
Check out this on status of claim and this will also give you an idea of timescale. If there are any issues please raise a Missing cashback claim first.
They should be able to resolve any query you have but if you do encounter any issues after that post back and let us know.
cheers
John
Community ModeratorJohnC
Show your appreciation!
Kudos”
Please avoid contacting us (moderators) via private message, for account/fault issues, unless invited to do so. The community will be able to help answer your question so we encourage you to create a new thread if you can’t find the answer from existing discussions. The moderators will be around to lend a hand should the community not have the answers. Thank You
