Disneylover
Message 1 of 6
Charged 42p twice for 2 calls landline to Mobile
Seems rather a lot when the mobile wasn't answered.  I was only ringing my mobile to see if it was ringing properly.  Should I query this or is it correct?
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Charged 42p twice for 2 calls landline to Mobile
Welcome to this user forum.
Its a 23p setup fee for each call, whether its answered or not.
https://www.productsandservices.bt.com/consumer/assets/downloads/BT_PhoneTariff_Residential.pdf
Disneylover
Message 3 of 6
I accept that (although I didn't know that before) but why the extra 19p per call?
Keith_Beddoe
Message 4 of 6
You would have to delve into the tariff guide to find out that, as there may be a minimum charge.
Devon_Dave
Distinguished Guru
Message 5 of 6
Did the call go to your voicemail service? If it did that is the same as the call being answered.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Disneylover
Message 6 of 6
No I don't believe so. I presume it is a minimum charge thing but I won't be making that mistake again.
