Message 1 of 15
Charges for 0871 number
I’m being charged by BT for landline calls to an 0871 number, 89 calls in total over a period of 5 days in mid March, calls happening at intervals including when there was no one at home and in the middle of the night, all lasting 6 seconds and costing 22p each. I contacted BT who did little to investigate the matter but as a “goodwill” gesture agreed to refund the charges incurred in my last billing period £7.14 but not those pending and which I’ll be charged for in the next bill £12.98.  Even a non expert can see my the charges have been fraudulently applied or someone has hacked or been able to recharge to my landline. BT customer service were more interested in trying to get me to upgrade to a new broadband package at over £20 pm more they’re offering to new customers. I’ve been with BT for nearly 30 years! Any suggestions how I can get the phone charges rectified?
14 REPLIES 14
Anonymous
Not applicable
Message 2 of 15
Re: Charges for 0871 number
Do you have an alarm connected to your phone line?
Have you Googled the number to try to establish what/who it is?
Message 3 of 15
Googled the number with no results and actually rang it as well and got “the number you have called has not been recognised”. BT customer service also did a search and came up with a bank in India. I explained that I had no reason for phoning a bank in India 89 times but to no avail!!!
Anonymous
Not applicable
Message 4 of 15
It would seem more than a little odd that you can be billed for a number that isn't valid! Even more so for that number to be associated with an international number.
There is a regulator for chargeable phone services where you can look up a number & make a report. Might be worth a try there if BT are being of no help.
https://psauthority.org.uk/
Just a thought but ii you're not on Digital Voice, try dialling 17070 & ensure that your number is reported back to you.
Message 5 of 15
Tried the 17070 check and it’s my landline number ok. Will try reporting the number as you suggest. Many thanks.
Message 6 of 15
What is the 0871 number in question  ?
If you don’t have a crossed line ( and have checked  that by using 17070 and it confirms you are connected to the correct telephone number ) , then its likely to be either someone accessing your line and making the calls , or it’s an auto dialer, it’s not just Alarms that can make automated calls on your line , but they are quite common, if it is someone else accessing your line , do you live in a MDU type situation ( apartment/ flats ) where someone could easily intercept your line and make the calls  ?
As stated , a lot makes no sense , if you call the number and it’s unobtainable then it’s not a charged for call , so wouldn’t appear on the bill , if it’s a number an automated dialer would call , then it would be answered by a modem , so would answer with ‘computer tones’ , basically the remote end computer asking the calling number ( your number ) to start transferring data , the repeated call attempts and very short duration calls , suggests a ‘dialer’ , as they tend to call multiple times if they don’t successfully connect , rather than fraud , perhaps someone with a financial interest in that 0871 number is generating their own income , and although that’s not impossible is very unlikely,  or , because some 0871 numbers  ,  are for adult entertainment, perhaps they only ‘work’ after certain hours , but you wouldn’t expect many short calls ( if it were someone using your line to call the adult service )
It’s a puzzle, but TBH , waiving the cost is the easiest ‘solution’ you will have to call again though if some calls are visible but not yet charged for ….if it happens again then further investigation may be needed, but generally it’s either a dialer or the bill payer doesn’t know who is using the line , but someone is .
Message 7 of 15
Will try Alarm provider in case it’s a fault at that end but I would have expected them to pick up 89 calls over this period and unusual pattern to their monitoring service. Thanks
Message 8 of 15
So you do you have an alarm connected to the phone line ?,
FWIW , some alarm companies use a premium number  ( that’s a bit cheeky to say the least ) but if they have technical problems, and the alarm constantly attempts connection , it may make you question the ‘fee’ , as even if it’s a small individual charge , that applied dozens of times , it can be considerable , when if it were a single call per month you probably wouldn’t notice .
If this issue is your alarm and alarm company, then BT waiving the call charges is a good result as arguably they are justified call charges that the alarm company should be refunding .
Anonymous
Not applicable
Message 9 of 15
I have unknown phone calls on my line.
     Do you have an alarm connected to the line?
Yes I do, but I'm keeping that a secret... 🙄
Message 10 of 15
Not sure what’s being implied with keeping alarm “secret.” This situation was fully explained to BT customer service and it was they who advised me the number was linked to a bank in India and were unable to investigate further, hence my post.
constructive comments only welcome- so much for community ethos!
