Message 1 of 3
Checking broadband useage
Hi
We're on Fibre 900. Usual "unlimited". Was reading that a well known EV maker was bringing in a data limit on his satellite broadband product, and that the average US home used about 450Gb a month. We stream a fair bit. Got me wondering, how much do we actually use. All I can find in BT is "don't worry, you're on unlimited".
I'm not worried, but would be interested to know what we get through. Did a search on here but couldnt find anything.
Is it possible to check? Via the router settings?
TIA.
2 REPLIES 2
Message 2 of 3
Re: Checking broadband useage
If you're using the SmartHub2 then you can get some idea from Broadband but of course this only covers the length of time that you have been online, see below for an example
Message 3 of 3
Cheers Les. Got it. Works best on a computer, via a browser, Advanced Settings/Technical log.
13 days uptime we downloaded 153GB and uploaded 48GB.
If that's average, pro rata'd out for the month would be around 480GB, so we're there or thereabouts with  US useage.
Interesting.
Thanks again.
