Cathyod12
Newbie
Message 1 of 3
Claiming bt rewards card
Hi I cant claim my bt rewards card when I log in the cards are there but theres no claim button to press.
2 REPLIES 2
-Richie-
Expert
Message 2 of 3
Re: Claiming bt rewards card
If you login then visit www.bt.com/claimmyreward it should allow you to claim.
BT employees can also claim on your behalf if you call 0800 800 150
Moderator
Moderator
Message 3 of 3
Hi @Cathyod12 following the advice from @-Richie-  did you manage to claim your reward card ok?
cheers
John
