seang
Message 1 of 5
Complaint Unresolved After 3 Months
Hi. Over 3 months ago I discovered I had two accounts, one of which was just for BT Sport. I didn't ever ask for this and it meant I was being overcharged by more than £30 per month. I raised this and was promised several times the accounts would be merged and I would be refunded and compensated. Nothing ever got done! I received a letter over a month ago saying BT were aware of my complaint and would be back in touch. No surprise I've heard nothing. Surely an easy fix - merge 2 accounts into 1 and refund the over charge total??! Not sure where to turn next to get this finally resolved. BT complaints handling is beyond farcical! Any guidance appreciated. Thanks.
4 REPLIES 4
Message 2 of 5
Re: Complaint Unresolved After 3 Months
I have asked mods who are BT employees to see if they can help. They will post here
Moderator
Moderator
Message 3 of 5
Hi @seang
Welcome to the Community and thanks for your post!
I'm really sorry that you are being over charged and I appreciate the amount of time you have spent trying to get this sorted out.  As you haven't been able to get this sorted up to this point we will step in and lend a hand from here.
I have sent you a private message with instructions on how you can send us over your details and we'll look into this for you. See: Private messages
Cheers,
Robbie
Community ModeratorRobbieMac
Show your appreciation!
Kudos”Kudos”
Moderator
Moderator
Message 4 of 5
Hi @seang I sent you a private message the other day as I missed you when I called. Can you get back to me on that to let me know if you're happy this is sorted?
Community ModeratorNeilO
Kudos”Kudos”
Moderator
Moderator
Message 5 of 5
Hi @seang thanks for marking the thread solved, you know where we are should you ever need any help with your BT services in the future.
Kudos”Kudos”
