michaelkatrine
Message 1 of 5
Connection issues - delays
Infinity Connection was mean’t to be 13th December ...after numerous chats/ calls I am still none the wiser as to actual issue and when or if infinity will ever be installed.
Sky had no issues connecting/ disconnecting normal broadband service....why can’t BT Just reconnect normal broadband service while they sort out infinity mess.
Very close to cancelling service and signing up to another supplier as I need service to be able to work from home. Happy to get an EE dongle and charge to BT if that is what it comes to but will be expensive.
4 REPLIES 4
Message 2 of 5
Re: Connection issues - delays
as it is openreach who work for all ISP apart from virgin that need to get you connected and cancelling and moving to another ISP will just move you further back in the queue you are already part of
Message 3 of 5
If you have placed an order for BT Infinity, then BT would not move you to ADSL unless you request it, however, if there iis a capacity issue at the cabinet, then you would lose your place in the waiting list.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Does it say there is a waiting list?
michaelkatrine
Message 4 of 5
So basically we are held to ransom by bt **bleep** processes...so when my house is burgled as security system is doen do i take lefal action against bt or openreach?
Message 5 of 5
Do you have dial tone on your phone line?
